SafeLine-CE 7.1.0
Improvements
  • System->Attack Alert add Telegram
  • Pro version supports deployment on ARM servers
  • Site detail add "Custom NGINX Config"
  • Clean Data add selection of cleaning 7 days, 15 days, or 30 days of data
  • Pro version add Anti-Replay in Anti-Bot
  • Improve the performance of data statistics and reduce memory usage
FIx
  • Fix the problem that the SSL protocol version will be reset after restarting
这是一个从 https://github.com/chaitin/SafeLine/releases/tag/v7.1.0 下的原始话题分离的讨论话题
