手撸XXL-JOB(二)——定时任务的管理
在上一节中,我们介绍了SpringBoot中关于定时任务的执行方式,以及ScheduledExecutorService接口提供的定时任务执行方法。假设我们现在要写类似XXL-JOB这样的任务调度平台,那么,对于任务的管理,是尤为重要的。接下来我们将一步一步,实现一个任务调度管理类。
YangJobManager类基础实现
假设我们现在的任务管理类,名为YangJobManager类。对于定时任务的执行,我们最终会调用到ScheduledExecutorService的相关方法,因此,我们的YangJobManager类,需要有ScheduledExecutorService属性,其次,我们希望能对要执行的定时线程任务,其命名进行修改,因此,我们需要有一个线程工厂的属性。基于上述两点,我们对YangJobManager类进行实现:
package com.yang.job;
import java.util.concurrent.ScheduledExecutorService;
import java.util.concurrent.ThreadFactory;
import java.util.concurrent.TimeUnit;
public class YangJobManager {
private ScheduledExecutorService scheduledExecutorService;
private ThreadFactory threadFactory;
public YangJobManager(ScheduledExecutorService scheduledExecutorService, ThreadFactory threadFactory) {
    this.scheduledExecutorService = scheduledExecutorService;
    this.threadFactory = threadFactory;
public void schedule(Runnable runnable, Long delay) {
    Thread thread = threadFactory.newThread(runnable);
    scheduledExecutorService.schedule(thread, delay, TimeUnit.SECONDS);
public void scheduleWithFixedDelay(Runnable runnable, Long delay, Long period) {
    scheduledExecutorService.scheduleWithFixedDelay(thread, delay, period, TimeUnit.SECONDS);
public void scheduleWithFixedRate(Runnable runnable, Long delay, Long period) {
    scheduledExecutorService.scheduleAtFixedRate(thread, delay, period, TimeUnit.SECONDS);
public void shutdown() {
    if (this.scheduledExecutorService == null) {
        return;
    if (this.scheduledExecutorService.isShutdown()) {
        return;
    scheduledExecutorService.shutdown();
        if (!scheduledExecutorService.awaitTermination(10, TimeUnit.SECONDS)) {
            scheduledExecutorService.shutdownNow();
    } catch (InterruptedException e) {
        e.printStackTrace();
然后,我们实现YangJobThreadFactory,完成对线程的命名
public class YangJobThreadFactory implements ThreadFactory {
    private String poolName;
private String threadPrefixName;
private static AtomicInteger poolNumber = new AtomicInteger(1);
private AtomicInteger threadNumber = new AtomicInteger(1);
public YangJobThreadFactory(String poolName) {
    this.poolName = poolName;
    this.threadPrefixName = poolName + "-pool-" + poolNumber.getAndIncrement() + "-thread-";
public String getPoolName() {
    return this.poolName;
@Override
public Thread newThread(Runnable r) {
    Thread thread = new Thread(r);
    thread.setName(this.threadPrefixName + threadNumber.getAndIncrement());
    return thread;
然后我们添加测试方法:
 public static void main(String[] args) {
        ThreadFactory threadFactory = new YangJobThreadFactory("yang");
        ScheduledExecutorService scheduledExecutorService = Executors.newScheduledThreadPool(4, threadFactory);
        YangJobManager yangJobManager = new YangJobManager(scheduledExecutorService, threadFactory);
    yangJobManager.schedule(() -> {
        System.out.println(Thread.currentThread().getName() + "schedule定时任务开始执行:" + new Date());
    }, 1L);
    yangJobManager.scheduleWithFixedDelay(() -> {
        System.out.println(Thread.currentThread().getName() + "withFixedDelay定时任务开始执行:" + new Date());
    }, 0L, 1L);
    yangJobManager.scheduleWithFixedRate(() -> {
        System.out.println(Thread.currentThread().getName() + "withFixedRate定时任务开始执行:" + new Date());
    }, 0L, 1L);
        Thread.sleep(20000);
        throw new RuntimeException(e);
    yangJobManager.shutdown();
执行结果如下:
提供统一的schedule方法
虽然我们能顺利将任务提交给YangJobManager执行,当感觉还不够收敛,因为我们创建了三个方法:schedule,scheduleWithFixedDelay, shceduleWithFixedRate,每个方法执行逻辑都差不多,最后都是调用scheduledExecutorService的相关方法,我们可以将这些方法都收敛到一个入口——schedule,然后在入参中添加一个参数,表示要执行的策略,根据入参的参数,选择对应的方法执行。 首先,我们添加一个执行策略枚举:
package com.yang.job.enums;
public enum JobExecuteStrategyEnum {
IMMEDIATE_EXECUTE(“immediate”, “立即执行”),
ONCE(“once”, “执行一次”),
WITH_FIXED_DELAY(“withFixedDelay”, “任务执行完毕后间隔执行”),
WITH_FIXED_RATE(“withFixedRate”, “任务执行开始后间隔执行”);
private String name;
private String description;
JobExecuteStrategyEnum(String name, String description) {
    this.name = name;
    this.description = description;
public String getName() {
    return this.name;
public static JobExecuteStrategyEnum getJobExecuteStrategyByName(String name) {
    if (name == null) {
        return null;
    for (JobExecuteStrategyEnum value : values()) {
        if (name.equals(value.getName())) {
            return value;
    return null;
public static boolean isLegal(String name) {
    JobExecuteStrategyEnum jobExecuteStrategyByName = getJobExecuteStrategyByName(name);
    return jobExecuteStrategyByName != null;
public String getDescription() {
    return description;
然后添加YangJobManager的schedule方法的入参类:
package com.yang.job.request;
import com.yang.job.enums.JobExecuteStrategyEnum;
import lombok.Data;
import java.io.Serializable;
@Data
public class YangJobSubmitParam implements Serializable {
private Runnable runnable;
private Integer initialDelay;
private Integer period;
private JobExecuteStrategyEnum jobExecuteStrategy;
最后,修改YangJobManager类,将执行定时任务收敛到schedule方法,进入该方法,首先根据入参判断执行策略,如果是immediate,那么直接对入参的runnable调用run方法执行接口,其他的策略则分别对应scheduledExecutorService的schedule、scheduledWithFixedDelay、scheduledWithFixedRate方法,此外,这里对属性也进行修改,去除ThreadFactory属性。
import com.yang.job.request.YangJobSubmitParam;
public YangJobManager(ScheduledExecutorService scheduledExecutorService) {
public void schedule(YangJobSubmitParam yangJobSubmitParam) {
    JobExecuteStrategyEnum jobExecuteStrategy = yangJobSubmitParam.getJobExecuteStrategy();
    if (jobExecuteStrategy == null) {
        throw new RuntimeException("缺少执行策略=========");
    Runnable runnable = yangJobSubmitParam.getRunnable();
    Integer initialDelay = yangJobSubmitParam.getInitialDelay();
    Integer period = yangJobSubmitParam.getPeriod();
    switch (jobExecuteStrategy) {
        case IMMEDIATE_EXECUTE:
            runnable.run();
            break;
        case ONCE:
            scheduledExecutorService.schedule(runnable, initialDelay, TimeUnit.SECONDS);
            break;
        case WITH_FIXED_DELAY:
            scheduledExecutorService.scheduleWithFixedDelay(runnable, initialDelay, period, TimeUnit.SECONDS);
            break;
        case WITH_FIXED_RATE:
            scheduledExecutorService.scheduleAtFixedRate(runnable, initialDelay, period, TimeUnit.SECONDS);
            break;
        return;
        return;
最后,我们添加测试方法:
        YangJobManager yangJobManager = new YangJobManager(scheduledExecutorService);
    YangJobSubmitParam yangJobSubmitParam1 = new YangJobSubmitParam();
    yangJobSubmitParam1.setRunnable(() -> System.out.println("立即执行======" + new Date()));
    yangJobSubmitParam1.setJobExecuteStrategy(JobExecuteStrategyEnum.IMMEDIATE_EXECUTE);
    YangJobSubmitParam yangJobSubmitParam2 = new YangJobSubmitParam();
    yangJobSubmitParam2.setRunnable(() -> System.out.println("执行一次======" + new Date()));
    yangJobSubmitParam2.setInitialDelay(1);
    yangJobSubmitParam2.setJobExecuteStrategy(JobExecuteStrategyEnum.ONCE);
    YangJobSubmitParam yangJobSubmitParam3 = new YangJobSubmitParam();
    yangJobSubmitParam3.setRunnable(() -> System.out.println("withFixedDelay=====" + new Date()));
    yangJobSubmitParam3.setInitialDelay(1);
    yangJobSubmitParam3.setPeriod(2);
    yangJobSubmitParam3.setJobExecuteStrategy(JobExecuteStrategyEnum.WITH_FIXED_DELAY);
    YangJobSubmitParam yangJobSubmitParam4 = new YangJobSubmitParam();
    yangJobSubmitParam4.setRunnable(() -> System.out.println("withFixedRate=====" + new Date()));
    yangJobSubmitParam4.setInitialDelay(1);
    yangJobSubmitParam4.setPeriod(2);
    yangJobSubmitParam4.setJobExecuteStrategy(JobExecuteStrategyEnum.WITH_FIXED_RATE);
    yangJobManager.schedule(yangJobSubmitParam1);
    yangJobManager.schedule(yangJobSubmitParam2);
    yangJobManager.schedule(yangJobSubmitParam3);
    yangJobManager.schedule(yangJobSubmitParam4);
执行结果如下:
提交任务和取消任务
任务的提交对应的是schedule方法,但我们的YangJobManager类缺少了关于任务的取消逻辑。在ScheduledExecutorService的各个定时执行方法中,其返回值是一个ScheduleFuture类,我们可以通过该类的cancel方法,来将对应的线程任务进行取消。此外,对于每一个任务,我们需要有一个任务标识,所以,我们先修改YangJobSubmitParam类:
import lombok.Data;
@Data
private Integer jobId;
然后,我们修改YangJobManager类,首先将schedule方法改为submit方法,这样更见名知义,在submit方法中,除了理解执行策略外,其他策略都会获取返回的ScheduleFuture,然后存入对应的map,在取消的时候,我们根据jobId从map中找到对应的ScheduleFuture,并执行cancel方法,以此来取消任务。
import java.util.Map;
import java.util.concurrent.ConcurrentHashMap;
import java.util.concurrent.ScheduledFuture;
private Map<string, scheduledfuture=""> jobId2ScheduleFutureMap = new ConcurrentHashMap&lt;&gt;();
public void submitJob(YangJobSubmitParam yangJobSubmitParam) {
    Integer jobId = yangJobSubmitParam.getJobId();
    if (jobId == null) {
        throw new RuntimeException("缺少任务标识=========");
    ScheduledFuture scheduledFuture = jobId2ScheduleFutureMap.get(jobId.toString());
    if (scheduledFuture != null &amp;&amp; !scheduledFuture.isCancelled()) {
        // jobId存在对应的任务
        return;
    if (jobExecuteStrategy == JobExecuteStrategyEnum.IMMEDIATE_EXECUTE) {
        yangJobSubmitParam.getRunnable().run();
        return;
    scheduledFuture = scheduleJob(yangJobSubmitParam);
    jobId2ScheduleFutureMap.put(jobId.toString(), scheduledFuture);
public void cancelJob(Integer jobId) {
        return;
    if (scheduledFuture == null) {
        return;
    if (!scheduledFuture.isCancelled()) {
        scheduledFuture.cancel(true);
    jobId2ScheduleFutureMap.remove(jobId.toString());
private ScheduledFuture scheduleJob(YangJobSubmitParam yangJobSubmitParam) {
        case ONCE:
            return scheduledExecutorService.schedule(runnable, initialDelay, TimeUnit.SECONDS);
            return scheduledExecutorService.scheduleWithFixedDelay(runnable, initialDelay, period, TimeUnit.SECONDS);
            return scheduledExecutorService.scheduleAtFixedRate(runnable, initialDelay, period, TimeUnit.SECONDS);
    throw new RuntimeException("执行策略有误===========");
        return;
        return;
</string,>
最后,我们添加对应的测试方法:
    YangJobSubmitParam yangJobSubmitParam = new YangJobSubmitParam();
    yangJobSubmitParam.setJobId(1);
    yangJobSubmitParam.setRunnable(() -&gt; System.out.println("执行任务=====" + new Date()));
    yangJobSubmitParam.setInitialDelay(0);
    yangJobSubmitParam.setPeriod(2);
    yangJobSubmitParam.setJobExecuteStrategy(JobExecuteStrategyEnum.WITH_FIXED_RATE);
    yangJobManager.submitJob(yangJobSubmitParam);
        Thread.sleep(10000);
    System.out.println("取消任务==========");
    yangJobManager.cancelJob(1);
在该方法中,我们提交任务,该任务间隔时间为2秒,10秒过后,取消任务,取消任务过后,再睡眠10秒,在后面10秒钟,不会执行任务(或执行一次,因为在cancel之前刚好有任务没执行完),执行结果如下:
YangJobManager建造者
对于YangJobManager,目前我们所拥有的属性、方法都比较简单,但是如果后续这个类进一步扩展,构造该类可能会变得很麻烦,因此,我们添加一个YangJobBuilder建造者类,用于构造YangJobManager,此外,我们将YangJobManager的构造方法设置为private,从而将构造YangJobManager的职责,彻底收敛到YangJobManagerBuilder类中,我们修改YangJobManager类如下:
import com.yang.job.factory.YangJobThreadFactory;
import java.util.concurrent.*;
private YangJobManager(ScheduledExecutorService scheduledExecutorService) {
        // jobId存在对应的任务
        return;
        return;
        return;
        return;
        case ONCE:
        return;
        return;
public static class YangJobManagerBuilder {
    public YangJobManagerBuilder() {
    public YangJobManagerBuilder setThreadFactory(ThreadFactory threadFactory) {
        return this;
    public YangJobManagerBuilder setScheduledExecutorService(ScheduledExecutorService scheduledExecutorService) {
        return this;
    public YangJobManager build() {
        if (this.threadFactory == null) {
            this.threadFactory = new YangJobThreadFactory("yang");
            this.scheduledExecutorService = Executors.newScheduledThreadPool(Runtime.getRuntime().availableProcessors(),
                    this.threadFactory);
            if (this.scheduledExecutorService instanceof ScheduledThreadPoolExecutor) {
                ScheduledThreadPoolExecutor scheduledThreadPoolExecutor = (ScheduledThreadPoolExecutor) this.scheduledExecutorService;
                scheduledThreadPoolExecutor.setThreadFactory(this.threadFactory);
        return new YangJobManager(this.scheduledExecutorService);
</string,>
任务执行类
在之前的代码中,我们的Runnable都是匿名函数类,但是在我们的定时任务调度平台中,一般情况下,这个任务是会持久化到数据库中的,我们一般不会说把这个Runnable的代码也存到数据库吧,一般存储的,应该就是某个任务执行类的类路径,和方法名,以及入参,然后在启动项目时,从数据库中加载这些数据,并通过反射或代理等方式,来构造这个Runnable。 首先,我们定义一个任务执行类,来规范任务的执行方法和入参格式:
// 任务执行类
package com.yang.job.execute;
public interface IYangJobExecutor {
void execute(YangJobExecuteRequest yangJobExecuteRequest);
// 任务执行方法入参
import lombok.Data;
import java.util.HashMap;
@Data
public class YangJobExecuteRequest implements Serializable {
private String jobId;
private Map<string, string=""> params = new HashMap&lt;&gt;();
public void addParam(String key, String value) {
    params.put(key, value);
public String getParam(String key) {
    return params.get(key);
</string,>
接着,我们创建这个YangJobExecutor的实现类,用于测试,在该类中,执行任务的方法很简单,打印当前类的名字以及入参。
package com.yang.task;
import com.yang.job.execute.IYangJobExecutor;
import com.yang.job.execute.YangJobExecuteRequest;
import java.util.Date;
public class TestJobExecutor implements IYangJobExecutor {
@Override
public void execute(YangJobExecuteRequest yangJobExecuteRequest) {
System.out.println(String.format(“%s 任务执行类执行了,入参为:%s, 当前时间:%s”,
this.getClass().getName(), yangJobExecuteRequest.toString(),
new Date().toString()));
然后我们创建一个YangJobData,假设我们从数据库中获取的数据格式如下:
package com.yang.job.data;
import lombok.Data;
@Data
public class YangJobData implements Serializable {
private String cron;
private String executeStrategy;
private String executeClassPath;
private String executeParams;
executeStrategy表示任务的执行策略,executeClassPath表示要执行的任务类的路径,executeParams表示执行任务方法的入参。 在XXL-JOB中,我们可以使用cron来设置定时任务的执行时间,因此我们这里,也使用cron作为定时任务的执行时间设置,为了解析cron表达式,我们添加下列依赖:
            com.cronutils
            cron-utils
            9.2.0
然后创建一个CronUtils工具类,用于解析cron表达式。
package com.yang.demo.infra.utils;
import com.cronutils.model.CronType;
import com.cronutils.model.definition.CronDefinition;
import com.cronutils.model.definition.CronDefinitionBuilder;
import com.cronutils.model.time.ExecutionTime;
import com.cronutils.parser.CronParser;
import java.time.ZonedDateTime;
import java.util.Optional;
public class CronUtils {
private static final CronDefinition CRON_DEFINITION = CronDefinitionBuilder.instanceDefinitionFor(CronType.QUARTZ);
private static final CronParser CRON_PARSER = new CronParser(CRON_DEFINITION);
public static ZonedDateTime nextExecutionTime(String cron, ZonedDateTime startTime) {
    ExecutionTime executionTime = ExecutionTime.forCron(CRON_PARSER.parse(cron));
    Optional<zoneddatetime> zonedDateTime = executionTime.nextExecution(startTime);
    return zonedDateTime.get();
对于执行方法的入参,一般情况下,就是任务的id,以及一些扩展信息,这些扩展信息一般以键值对的形式存储,即"key:value;key:value;"这些形式,所以这里添加一个FeaturesUtils类,用于解析这些键值对信息:
package com.yang.job.utils;
public class FeaturesUtils {
private final static String KEY_KEY_SEPARATOR = “;”;
private final static String KEY_VALUE_SEPARATOR = “:”;
public static Map<string, string=""> convert2FeatureMap(String features) {
    Map<string, string=""> featureMap = new HashMap&lt;&gt;();
    if (features == null || features.isEmpty()) {
        return featureMap;
    String[] keyValues = features.split(KEY_KEY_SEPARATOR);
    for (String keyValue : keyValues) {
        String[] split = keyValue.split(KEY_VALUE_SEPARATOR);
        String key = split[0];
        String value = split[1];
        featureMap.put(key, value);
    return featureMap;
public static String convert2Features(Map<string, string=""> featureMap) {
    if (featureMap == null || featureMap.isEmpty()) {
        return "";
    StringBuilder stringBuilder = new StringBuilder();
    featureMap.forEach((key, value) -&gt; {
        stringBuilder.append(key)
                .append(KEY_VALUE_SEPARATOR)
                .append(value)
                .append(KEY_KEY_SEPARATOR);
    return stringBuilder.toString();
</string,></string,></string,>
然后我们添加测试方法,模拟从数据库中获取数据,并根据任务类路径,获取对应的runnable并提交到YangJobManager中。
        YangJobData yangJobData = mockYangJobData();
        YangJobSubmitParam yangJobSubmitParam = convert2YangJobSubmitParam(yangJobData);
    YangJobManager yangJobManager = new YangJobManager.YangJobManagerBuilder()
            .setThreadFactory(new YangJobThreadFactory("yang"))
            .build();
private static YangJobSubmitParam convert2YangJobSubmitParam(YangJobData yangJobData) {
    yangJobSubmitParam.setJobId(yangJobData.getJobId());
    yangJobSubmitParam.setJobExecuteStrategy(JobExecuteStrategyEnum.getJobExecuteStrategyByName(yangJobData.getExecuteStrategy()));
    ZonedDateTime nextExecutionTime = CronUtils.nextExecutionTime(yangJobData.getCron(), ZonedDateTime.now());
    ZonedDateTime nextNextExecutionTime = CronUtils.nextExecutionTime(yangJobData.getCron(), nextExecutionTime);
    long nowEochMill = ZonedDateTime.now().toInstant().toEpochMilli();
    long executeEochMill = nextExecutionTime.toInstant().toEpochMilli();
    long secondExecuteEochMill = nextNextExecutionTime.toInstant().toEpochMilli();
    yangJobSubmitParam.setInitialDelay((int)(executeEochMill - nowEochMill) / 1000);
    yangJobSubmitParam.setPeriod((int)(secondExecuteEochMill - executeEochMill) / 1000);
        Class<!--?--> aClass = Class.forName(yangJobData.getExecuteClassPath());
        if (!IYangJobExecutor.class.isAssignableFrom(aClass)) {
            throw new RuntimeException("任务类必须实现IYangJobExecutor接口");
        IYangJobExecutor executor = (IYangJobExecutor) aClass.newInstance();
        YangJobExecuteRequest yangJobExecuteRequest = convert2YangJobExecuteRequest(yangJobData);
        Runnable runnable = () -&gt; executor.execute(yangJobExecuteRequest);
        yangJobSubmitParam.setRunnable(runnable);
    } catch (InstantiationException | IllegalAccessException e) {
    } catch (ClassNotFoundException e) {
    return yangJobSubmitParam;
private static YangJobExecuteRequest convert2YangJobExecuteRequest(YangJobData yangJobData) {
    YangJobExecuteRequest yangJobExecuteRequest = new YangJobExecuteRequest();
    yangJobExecuteRequest.setJobId(yangJobData.getJobId().toString());
    yangJobExecuteRequest.setParams(FeaturesUtils.convert2FeatureMap(yangJobData.getExecuteParams()));
    return yangJobExecuteRequest;
private static YangJobData mockYangJobData() {
    YangJobData yangJobData = new YangJobData();
    yangJobData.setJobId(1);
    yangJobData.setCron("0/5 * * * * ?");
    yangJobData.setExecuteStrategy(JobExecuteStrategyEnum.WITH_FIXED_DELAY.getName());
    yangJobData.setExecuteClassPath("com.yang.task.TestJobExecutor");
    yangJobData.setExecuteParams("jobId:1;startIndex:1;endIndex:10;");
    return yangJobData;
这里对于cron的解析,其实不是特别好,这里的思路是,获取下一次执行的时间,和下下一次执行的时间,然后以此来计算initialDelay和period,但是如果这个cron表示的是某几天、某几个小时,比如说星期一、星期二、星期三执行,那么我们那种解析方式是有误的,这个可以后续再好好斟酌一下,目前先这样解析。 执行结果如下:
这是一个从 https://juejin.cn/post/7368477662375428123 下的原始话题分离的讨论话题
