WordPress 6.6 Release Candidate 2
WordPress 6.6 RC2 is ready for download and testing!
This version of the WordPress software is under development. Please do not install, run, or test this version of WordPress on production or mission-critical websites. Instead, please evaluate RC2 on a test server or a local environment.
Reaching this phase of the release cycle is a worthy achievement. While release candidates are considered ready for release, your testing is still vital to make sure everything in WordPress 6.6 is the best it can be.
You can test WordPress 6.6 RC2 in four ways:
PluginInstall and activate the WordPress Beta Tester plugin on a WordPress install. (Select the “Bleeding edge” channel and “Beta/RC Only” stream).
Direct DownloadDownload the RC2 version (zip) and install it on a WordPress website.
Command LineUse the this WP-CLI command:
wp core update --version=6.6-RC2
WordPress PlaygroundUse the 6.6 RC2 WordPress Playground instance (available within 35 minutes after the release is ready) to test the software directly in your browser without the need for a separate site or setup.
Please test WordPress 6.6 RC2 in one or more of these four ways.
The target for the WordPress 6.6 release is July 16, 2024. Get an overview of the 6.6 release cycle, and check the Make WordPress Core blog for 6.6-related posts in the next few weeks for further details.
What’s in WordPress 6.6 RC2?
Thanks to your testing and many other contributors‘ up to now, this release includes more than 19 bug fixes for the Editor and more than 20 tickets for WordPress Core.
Get a recap of WordPress 6.6’s highlighted features in the Beta 1 announcement. For more technical information related to issues addressed since Beta 3, you can browse the following links:
Want to look deeper into the details and technical notes for this release? You might want to make your first stop The WordPress 6.6 Field Guide. Then, check out this list:
You can contribute. Here’s how
WordPress is the world’s most popular open source web platform, thanks to a passionate community of people who collaborate on its development in a wide variety of ways. You can help—whether or not you have any technical expertise.
Get involved in testing
Testing for issues is critical to keeping WordPress speedy, stable, and secure. It’s also a vital way for anyone to contribute. This detailed guide will walk you through testing features in WordPress 6.6. If you’re new to testing, follow this general testing guide for more details on getting set up.
If you encounter an issue, please report it to the Alpha/Beta area of the support forums. If you are comfortable writing a reproducible bug report, you can also report it on WordPress Trac. Before you do either, you may want to check your issue against a list of known bugs.
Curious about testing releases in general? Follow along with the testing initiatives in Make Core and join the #core-test channel on Making WordPress Slack.
Search for vulnerabilities
From now until the final release candidate of WordPress 6.6 (scheduled for July 9), the financial reward for reporting new, unreleased security vulnerabilities doubles. Please follow responsible disclosure practices as detailed in the project’s security practices and policies outlined on the HackerOne page and in the security white paper.
Update your theme or plugin
If you build themes, plugins, blocks, or patterns, your products play an integral role in extending the functionality and value of WordPress for all users.
Thanks for continuing to test your products with the WordPress 6.6 beta releases. With RC2, you’ll want to finish your testing and update the “Tested up to” version in your plugin’s readme file to 6.6.
If you find compatibility issues, please post detailed information to the support forum.
Help translate WordPress
Do you speak a language other than English? ¿Español? Français? Русский? 日本語? हिन्दी? বাংলা? You can help translate WordPress into more than 100 languages.
Release the haiku
6.6 draws near.
In two weeks the final’s here.
Test. Test. Then test more.
Props to @juanmaguitar, @meher, @desrosj and @atachibana for peer review.
这是一个从 https://wordpress.org/news/2024/07/wordpress-6-6-release-candidate-2/ 下的原始话题分离的讨论话题
