新年快乐
- 修复解压缩不支持.gz
- 修复文件重命名错误提示文件已存在
- 修复重命名之后文件列表没有刷新
- 修复日志切割脚本没有单引号
- 修复部分tips出错时未关闭
- 修复恢复数据库带压缩备份时报错
- 优化有任务运行则跳过自动更新
- 优化redis支持设置密码情况下查看负载
- 优化面板systemd服务文件权限
- 优化前端部分表格加载
- 01eb10b fix: ci
- 8637650 feat: alova.js替换axios
- 39fd752 feat: alova.js替换axios
- 0b6eed5 feat: alova.js替换axios
- 9a81c77 feat: alova.js替换axios
- 03c375e Merge remote-tracking branch 'origin/main'
- 645e6d6 feat: alova.js替换axios
- 2b112d7 chore(deps): Update dependency vite to v6.1.0 (#521)
- 4632cf7 Merge remote-tracking branch 'origin/main'
- b15262b feat: 统统变any
- b25456e chore(deps): Update dependency @iconify/json to v2.2.303 (#520)
- 398bdce Merge remote-tracking branch 'origin/main'
- d25c035 feat: axios转alova.js
- 486cbe0 chore(deps): Update module github.com/go-chi/chi/v5 to v5.2.1 (#519)
- 06d620a fix: lint
- aa66197 fix: lint
- 74261f4 fix: 修复恢复数据库压缩备份pattern contains path separator
- 50ec26e fix: 部分tips出错时未关闭
- dff6d27 chore(deps): Update dependency @types/node to v22.13.1 (#518)
- e370397 chore(deps): Lock file maintenance (#517)
- 0cd49a3 chore(deps): Update non-major dependencies (#516)
- 1ad51e0 chore(deps): Update dependency @types/node to v22.13.0 (#515)
- 405d839 chore(deps): Update dependency vue-i18n to v11.1.0 (#514)
- c4727dc chore(deps): Update dependency cronstrue to v2.54.0 (#513)
- 19d1169 chore(deps): Update dependency @iconify/json to v2.2.301 (#512)
- e95fb84 chore(deps): Update module github.com/samber/lo to v1.49.1 (#511)
- 2e0def6 chore(deps): Update dependency @types/node to v22.12.0 (#510)
- a4d12f8 chore(deps): Update dependency @iconify/json to v2.2.300 (#509)
- 8a2c241 chore(deps): Lock file maintenance (#508)
- e79d4b4 chore(deps): Update module github.com/samber/lo to v1.49.0 (#507)
- 169b8c7 chore(deps): Update non-major dependencies (#506)
- 68eb239 chore(deps): Update dependency @types/node to v22.10.10 (#505)
- 93f4797 chore(deps): Update non-major dependencies (#504)
- 170453e chore(deps): Update dependency @types/node to v22.10.8 (#503)
- 6e44504 chore(deps): Update non-major dependencies (#502)
- 27c851b chore(deps): Update module github.com/go-rat/utils to v1.0.9 (#501)
- 03c71a3 chore(deps): Update dependency vite to v6.0.11 (#500)
- 95d88cc chore(deps): Update non-major dependencies (#499)
- db909f1 chore(deps): Update module github.com/go-rat/utils to v1.0.8 (#498)
- 27c0451 chore(deps): Update dependency vite to v6.0.9 (#497)
- 6b66552 chore(deps): Update non-major dependencies (#496)
- c873f85 chore(deps): Lock file maintenance (#495)
- 61b93c8 chore(deps): Update dependency @vue/eslint-config-prettier to v10.2.0 (#494)
- 7181390 Merge remote-tracking branch 'origin/main'
- 2a9a630 feat: 优化systemd服务文件权限
- 22222f0 chore(deps): Update dependency @iconify/json to v2.2.297 (#493)
- 74380a5 chore(deps): Update dependency @iconify/json to v2.2.296 (#492)
- 43764cf Merge remote-tracking branch 'origin/main'
- 6cec736 fix: lint
- d9138dd chore(deps): Update non-major dependencies to v65.4.2 (#491)
- 73c2c31 chore(deps): Update dependency @types/node to v22.10.7 (#490)
- f6bd27a feat: 添加新赞助商
- 47df0ab feat: 添加新赞助商
- 35d7049 Merge remote-tracking branch 'origin/main'
- 438f7fd feat: 添加新赞助商
- 5cc2ae1 chore(deps): Update dependency cronstrue to v2.53.0 (#489)
- f4af131 Merge remote-tracking branch 'origin/main'
- c966920 feat: rename slogGorm to sloggorm
- a80b0ff chore(deps): Lock file maintenance (#488)
- c1ed517 chore(deps): Lock file maintenance (#487)
- 7b8575b chore(deps): Update dependency @vue/eslint-config-typescript to v14.3.0 (#486)
- 48c41c7 chore(deps): Update dependency unplugin-icons to v22 (#483)
- 16791f3 chore(deps): Update unocss monorepo to v65 (#485)
- 34e0073 chore(deps): Update dependency unplugin-vue-components to v28 (#484)
- c54bff4 chore(deps): Update dependency unplugin-auto-import to v19 (#482)
- 3b73840 chore(deps): Update non-major dependencies (#481)
- 3f83119 fix: 日志切割脚本没有单引号
- 0eae148 fix: 重命名之后文件列表没有刷新
- 7a64809 fix: redis支持设置密码情况下查看负载
- 6de5e79 fix: 文件重命名错误提示文件已存在
- 36d7575 fix: test
- 48a49db fix: 解压缩不支持.gz
- a573a6e feat: 有任务运行则跳过自动更新
这是一个从 https://github.com/tnb-labs/panel/releases/tag/v2.4.4 下的原始话题分离的讨论话题
