V2.4.0
  1. 重构面板核心框架,更轻更快
  2. 修复数据库链接泄漏问题
  3. 修复计划任务启用后仍显示未启用
  4. 优化客户端 hash 计算
  5. 优化移除 zap 依赖
  6. 优化 phpredis 拓展的描述
  7. 添加 pgsql 拓展
  8. 优化降低 aes 测试难度
  9. 优化证书列表操作列宽度
  10. 优化文件未知用户时的显示
  11. 优化面板工作流
  • 3bdfb7f workflow: fix version
  • d51d419 fix: 验证器错误
  • 70d9e5e chore(deps): Update dependency @iconify/json to v2.2.290 (#474)
  • 31d1df1 workflow: try fix copy
  • 96cc853 workflow: try fix copy
  • e583967 chore: optimize auto import
  • f7b0798 chore: add .eslintrc-auto-import.json to gitignore
  • 7c3e11a workflow: fix goreleaser
  • f3baff2 fix: 版权声明
  • ba544e3 feat: 优化内存参数
  • 37119d1 feat[文件]: 优化未知用户显示
  • 2d0a0d5 fix: fix #443
  • 7d48a80 feat: 优化证书列表操作列
  • def1f2d Merge remote-tracking branch 'origin/main'
  • b5f2475 feat: 优化验证规则
  • e9a6fc0 chore(deps): Update dependency typescript to v5.7.2 (#473)
  • f71456d feat: 优化验证规则
  • 3b332cf fix: nginx parser
  • 50979e1 chore(deps): Update dependency echarts to v5.6.0 (#472)
  • 84b154f feat: 添加pgsql拓展
  • ca78656 chore: update renovate config
  • 67537ef fix: build
  • bd365c4 chore: update dependences
  • d47a764 chore(deps): Update non-major dependencies
  • 69d5d5c chore(deps): Update dependency vue-i18n to v11 (#470)
  • b515019 chore(deps): Lock file maintenance (#469)
  • d3309c3 workflow: 合并前后端工作流
  • bbe07f7 workflow: 合并前后端工作流
  • c5b23aa chore: add .gitkeep
  • ef60a44 chore: update build config
  • 0bea527 chore: update renovate config
  • c1b2708 chore(deps): Update module github.com/mholt/acmez/v3 to v3.0.0 (#467)
  • b264e5d chore: update renovate config
  • 2deced3 chore(deps): Update all dependencies (#466)
  • 6c274f1 chore(deps): Update dependency @iconify/json to v2.2.286 (#465)
  • a279a45 chore(deps): Update all dependencies (#464)
  • 12b5daf chore(deps): Update module github.com/spf13/cast to v1.7.1 (#463)
  • 03c74b2 feat(跑分): 降低 aes 测试难度
  • c3e0bf7 chore(deps): Update dependency @iconify/json to v2.2.285 (#461)
  • cd815fb chore(deps): Update module github.com/TheTNB/acmez/v3 to v3.0.0-20241217024017-a2f2c48efdcc (#460)
  • 8d70840 chore(deps): Update all dependencies (#459)
  • 98eeec7 chore(deps): Update dependency pinia-plugin-persistedstate to v4.2.0 (#457)
  • 5542ec2 chore(deps): Update dependency npm-run-all2 to v7.0.2 (#456)
  • 1565bcf chore(deps): Update dependency @iconify/json to v2.2.284 (#454)
  • 0f11812 chore(deps): Update all dependencies (#453)
  • a27cae1 chore(deps): Update dependency unplugin-vue-components to ^0.28.0 (#452)
  • c262183 fix: render release
  • aae3951 chore(deps): Lock file maintenance (#451)
  • 083c6bf chore(deps): Lock file maintenance (#450)
  • 34fbda8 chore(deps): Lock file maintenance (#449)
  • f8aa893 chore(deps): Update module github.com/go-chi/chi/v5 to v5.2.0 (#447)
  • c099076 chore(deps): Lock file maintenance (#448)
  • ed31eb6 feat: go mod tidy
  • 015fb76 feat: 生成mock
  • a70f390 fix: 计划任务启用后仍显示未启用
  • a3bd4c5 feat: 同步验证器修改
  • a64660d refactor: 应用支持依赖注入
  • 1fdc86c fix: lint
  • fe4f0d6 feat: 中间件注入
  • 8116ea7 fix: jobs
  • 2050a96 fix: 加解密
  • cd1d7c9 refactor: 初步实现依赖注入
  • 24af7ba refactor: 替换验证器
  • 81be655 feat: 修改phpredis的描述
  • 5b5e10d chore: 优化bug模板
  • c73e3d0 chore: 优化ci及问题模板
  • af25b67 chore: 优化ci及问题模板
  • f8b718d workflow: remove auto reply
  • 7792174 chore(deps): Update dependency marked to v15.0.4 (#444)
  • 6eced53 workflow: 缩短运行间隔
  • 7315b3d feat: 移除内存优化
  • 567b5ea feat: 更新文档
  • 8d4a2c3 feat: 更新文档
  • 3ffafee feat: 更新文档
  • 423cd48 chore(deps): Update module github.com/mholt/acmez/v3 to v3.0.0-20241214053340-45433dfc1161 (#442)
  • b169514 chore(deps): Update dependency eslint to v9.17.0 (#441)
  • c15000d chore(deps): Update all dependencies (#440)
  • 27d2eaa chore(deps): Update dependency sass to v1.83.0 (#439)
  • 48e52f2 chore(deps): Update dependency @iconify/json to v2.2.282 (#438)
  • 1252a02 chore(deps): Update module github.com/bddjr/hlfhr to v1.3.5 (#437)
  • 38c99f4 chore(deps): Update module golang.org/x/crypto to v0.31.0 (#436)
  • 906e606 chore(deps): Update all dependencies (#435)
  • b47b8b5 chore(deps): Update dependency monaco-editor to v0.52.2 (#434)
  • 1902a59 feat: 优化客户端hash使用sha256计算
  • 939d108 Merge remote-tracking branch 'origin/main'
  • 19a0d23 feat: 优化移除zap
  • 984e320 chore(deps): Update all dependencies (#433)
  • 2d203de chore(deps): Lock file maintenance (#432)
  • bc72ece chore(deps): Update dependency @iconify/vue to v4.2.0 (#431)
  • 6393721 fix: 数据库链接内存泄漏
  • 9cfc241 chore(deps): Update dependency @iconify/json to v2.2.280 (#430)
  • d37433c chore(deps): Update dependency vite to v6.0.3 (#429)
  • ef3badd docs: update ui.png
  • 0986a02 docs: update alipay qr code
  • 38c7c3a chore(deps): Update github.com/tufanbarisyildirim/gonginx digest to 3234810 (#428)
  • 20a6441 chore(deps): Update all dependencies (#427)
  • bfa189e chore(deps): Update dependency pinia to v2.3.0 (#426)
  • 4bc7fd3 chore(deps): Update module github.com/bddjr/hlfhr to v1.3.1 (#425)
  • 276ca5d chore(deps): Update all dependencies (#424)
  • 857637e chore(deps): Update module github.com/bddjr/hlfhr to v1.3.0 (#423)
这是一个从 https://github.com/TheTNB/panel/releases/tag/v2.4.0 下的原始话题分离的讨论话题
