- 本次更新后需要重新设置终端之前所有主机的密码
- 添加 memcached PHP 拓展
- 优化首页负载条不允许超过 100%
- 优化 PHP 拓展安装添加确认弹窗
- 优化防止任务重复提交
- 优化文件路径切换后清空已选择
- 优化对部分密码进行加密
- 优化 IP 地址获取
- 添加数据库相关迁移,为数据库管理做准备
- d64f099 feat: 发布v2.3.18
- 294a78c feat: 优化删除检查
- 8294a1a chore(deps): Update module github.com/urfave/cli/v3 to v3.0.0-alpha9.3 (#349)
- c403efd chore(deps): Update dependency @iconify/json to v2.2.270 (#348)
- cf8dfca Merge remote-tracking branch 'origin/main'
- e552caa feat: 修改ip获取地址
- ddff139 chore(deps): Update dependency marked to v15 (#347)
- 27f79ea chore(deps): Update dependency pinia-plugin-persistedstate to v4.1.3 (#346)
- 04d5701 feat: 添加redis驱动
- 8e74428 chore(deps): Update all dependencies (#345)
- f4c0932 chore(deps): Update dependency md-editor-v3 to v4.21.3 (#344)
- ee6a12f chore(deps): Update module golang.org/x/crypto to v0.29.0 (#343)
- ba42906 chore(deps): Update dependency marked to v14.1.4 (#342)
- 711ccb4 chore(deps): Update dependency @iconify/json to v2.2.269 (#341)
- 7d6e078 chore: 添加新合作
- d3a7c9e feat: 数据库密码可以为空(本地认证)
- 10d22bf feat: 初始化数据库服务
- 724d05d feat: 优化数据库模型
- 690e7f0 feat: 重命名安全为数据库
- a28fc59 feat: 优化数据库模型
- ff7e76a feat: 初始化数据库条目模型
- f2eb3a1 feat: 对部分密码进行加密
- 020a4ad chore(deps): Update all dependencies (#340)
- b5e7cfc chore(deps): Update all dependencies (#339)
- 52f8a6f chore(deps): Update dependency @types/node to v22.9.0 (#338)
- 3831d47 feat(文件): 路径切换后清空已选择
- 3a579f2 feat: 运行等待任务前标记先前运行中的任务为失败
- e85e8df fix: lint
- e18d40b feat: 防止任务重复提交
- c308b8e chore(deps): Update all dependencies (#336)
- cafded5 chore(deps): Lock file maintenance (#335)
- 99aa6c9 chore(deps): Update dependency pinia to v2.2.6 (#334)
- e0daee4 feat: 移动部分方法到utils
- bf8c832 feat: 去掉重复的方法
- 2d35cbc fix: lint
- 6b51f58 chore(deps): Update dependency @types/node to v22.8.7 (#330)
- f58c680 chore(deps): Update dependency @iconify/json to v2.2.267 (#329)
- 9c6d0b5 feat: php拓展安装添加确认弹窗
- d069cbe feat: 负载条不允许超过100%
- 9b252aa docs: 更新文档
- a52d06e feat: 添加memcached php拓展
这是一个从 https://github.com/TheTNB/panel/releases/tag/v2.3.18 下的原始话题分离的讨论话题
