✨ New Features / 新增功能
- Added TCP/UDP proxy feature / 新增 TCP/UDP 代理功能 by @zhengkunwang223 in #11302
- Support batch configuration of website SSL certificates / 支持批量配置网站 SSL 证书 by @zhengkunwang223 in #11339
- Support SSL certificate issuance for IP addresses / 支持 IP 地址签发 SSL 证书 by @zhengkunwang223 in #11437
- View GPU real-time and historical monitoring data / 支持查看 GPU 实时和历史监控数据 by @ssongliu in #11303
- Database restore operation supports setting timeout / 数据库恢复操作支持设置超时时间 by @ssongliu in #11338
- Terminal configuration supports resetting default connection information / 终端配置支持重置默认连接信息 by @ssongliu in #11336
- Port forwarding supports configuring port ranges / 端口转发支持配置端口范围 by @endymx in #11188
- Support centralized management and updating of applications on nodes / 支持集中管理和更新各节点上的应用 by @zhengkunwang223 in #11325
- Task center page supports switching nodes / 任务中心页面支持切换节点 by @zhengkunwang223 in #11315
⚙️ Enhancements / 功能优化
- Optimized HTTP to HTTPS redirect rules for non-443 port websites / 优化非 443 端口网站的 HTTP 到 HTTPS 跳转规则 by @zhengkunwang223 in #11364
- Optimized website creation interface and logic to improve user experience / 优化网站创建界面和逻辑提升使用体验 by @HynoR in #11331
- Support Unicode display for Chinese and special character domains / 支持中文及特殊字符域名的 Unicode 显示 by @HynoR in #11433
- Optimized scrolling effect of left menu in website configuration page / 优化网站配置页面左侧菜单滚动效果 by @zhengkunwang223 in #11423
- Optimized PHP extension installation prompts / 优化 PHP 扩展安装提示 by @zhengkunwang223 in #11352
- PHP runtime environment supports fast installation of lz4 extension / PHP 运行环境支持快速安装 lz4 扩展 by @zhengkunwang223 in #11279
- Optimized prompt information when deleting containers / 优化删除容器时的提示信息 by @zhengkunwang223 in #11316
- Container orchestration supports operating on .env files / 容器编排支持操作 .env 文件 by @ssongliu in #11274
- Optimized container orchestration creation method / 优化容器编排创建方式 by @ssongliu in #11274
- Optimized display style of associated container resources / 优化容器关联资源的样式显示 by @ssongliu in #11278
- Optimized image deletion dependency prompt messages / 优化镜像删除依赖提示消息 by @ssongliu in #11407
- Support viewing files larger than 10MB / 支持查看大于 10MB 的文件 by @HynoR in #11200
- Optimized file upload page button layout / 优化文件上传页面按钮布局 by @lan-yonghui in #11354
- Allow UDP 443 port by default to support HTTP/3 (QUIC) / 默认放通 UDP 443 端口支持 HTTP/3(QUIC) by @HynoR in #11432
- Optimized host selection dialog style / 优化主机选择弹框样式 by @ssongliu in #11425
- Optimized prompt information when syncing WAF IP groups / 优化同步 WAF IP 组时的提示信息 by @zhengkunwang223 in #11317
- Retain custom style configuration after restarting watermark feature / 重启水印功能后保留自定义样式配置 by @ssongliu in #11429
- Optimized display position of prompt information on some pages / 优化部分页面的提示信息显示位置 by @zhengkunwang223 in #11389
- Optimized two-factor authentication input box experience / 优化两步验证输入框体验 by @Kadxy in #11297
- Optimized 1pctl rollback command prompt information / 优化 1pctl 回滚命令后提示信息 by @ssongliu in #11378
- Optimized SSH session acquisition logic to reduce unnecessary performance overhead / 优化 SSH 会话获取逻辑以减少不必要的性能开销 by @HynoR in #11210
- Clean up redundant upgrade temporary files after upgrade / 升级完成后清理多余的升级临时文件 by @ssongliu in #11255
- Optimized Swagger API documentation format / 优化 Swagger API 文档格式 by @lan-yonghui in #11207
- Simplified process data handling to improve performance / 简化进程数据处理逻辑以提升性能 by @HynoR in #11236
- Optimized network connection and WebSocket handling to improve performance / 优化网络连接和 WebSocket 处理以提升性能 by @HynoR in #11269
- Optimized process and link pages to improve user experience / 优化进程和链接页面功能提升使用体验 by @HynoR in #11270
- Enhanced browser cache management and localization support / 增强浏览器缓存管理和本地化支持 by @HynoR in #11277
🛠️ Bug Fixes / 问题修复
- Fixed issue where some applications could not select MySQL charset properly / 修复了部分应用无法正常选择 MySQL 字符集的问题 by @zhengkunwang223 in #11396
- Fixed local applications not updating properly across major versions / 修复了本地应用跨大版本更新配置不生效的问题 by @zhengkunwang223 in #11333
- Fixed issue where redirect configurations over 100 entries could not be fully displayed / 修复了重定向配置超过 100 条后无法全部显示的问题 by @zhengkunwang223 in #11424
- Fixed issue where one-click deployment websites failed to create in some scenarios / 修复了部分场景下一键部署类型网站创建失败的问题 by @zhengkunwang223 in #11301
- Fixed timeout errors in website settings in some scenarios / 修复了部分场景下网站设置超时报错的问题 by @zhengkunwang223 in #11370
- Fixed PostgreSQL database backup failures in some scenarios / 修复了部分场景下 PostgreSQL 数据库备份失败的问题 by @ssongliu in #11295
- Fixed multi Compose YAML combination failures / 修复了多 Compose YAML 组合操作失败的问题 by @ssongliu in #11421
- Fixed incomplete log printing after container orchestration creation failures / 修复了容器编排创建失败后日志打印不完整的问题 by @ssongliu in #11357
- Fixed container orchestration creation failures in some scenarios / 修复了部分场景下容器编排创建失败的问题 by @ssongliu in #11280
- Fixed failures when deleting non-existent symlink files in some scenarios / 修复了部分情况下删除不存在的软链接文件失败的问题 by @zhengkunwang223 in #11373
- Fixed port forwarding initialization state judgment anomaly / 修复了端口转发初始化状态判断异常的问题 by @ssongliu in #11276
- Fixed UFW firewall adding IPv6 address error / 修复了 UFW 防火墙添加 IPv6 地址报错的问题 by @ssongliu in #11349
- Fixed manual stop task not working in some scenarios / 修复了部分场景下手动停止任务无效的问题 by @ssongliu in #11300
- Fixed heterogeneous architecture node version update failures / 修复了异构架构从节点版本更新失败的问题 by @ssongliu
- Fixed spider count display errors in some scenarios / 修复了部分场景下蜘蛛数量显示错误的问题 by @zhengkunwang223
- Fixed local application backup failures when creating snapshots / 修复了创建快照时本地应用备份失败的问题 by @ssongliu in #11341
- Fixed container configuration errors when adding HTTP/HTTPS proxy / 修复了添加 HTTP/HTTPS 代理时容器配置报错的问题 by @ssongliu in #11258
- Fixed possible blocking when writing monitoring data / 修复了监控数据写入可能阻塞的问题 by @ssongliu in #11312
- Fixed some task names not internationalized / 修复了部分任务名称未国际化的问题 by @ssongliu in #11368
- Fixed garbled output in task logs in some scenarios / 修复了部分场景下任务日志输出乱码的问题 by @ssongliu in #11363
- Fixed focus loss in file selection component in some scenarios / 修复了部分场景下文件选择组件焦点异常丢失的问题 by @ssongliu in #11281
- Fixed version update failures in some scenarios / 修复了部分场景下版本更新失败的问题 by @ssongliu in #11322
这是一个从 https://github.com/1Panel-dev/1Panel/releases/tag/v2.0.16 下的原始话题分离的讨论话题
