๐ Quick Start
Execute the script below and follow the prompts to install 1Panel:
curl -sSL https://resource.1panel.pro/quick_start.sh -o quick_start.sh && bash quick_start.shPlease refer to our documentation for more details.
๐ ๏ธ Bug Fixes
- Fixed the issue where GPU configuration was lost when comparing application versions after enabling GPU support by @zhengkunwang223 in #9362
- Fixed the issue where default client authentication for OneDrive was invalid by @ssongliu in #9440
- Fixed the issue where editing an HTTPS image registry would cause Docker to restart by default by @ssongliu in #9447
- Fixed console errors on some pages (F12) by @ssongliu in #9455
่ฟๆฏไธไธชไป https://github.com/1Panel-dev/1Panel/releases/tag/v1.10.32-lts ไธ็ๅๅง่ฏ้ขๅ็ฆป็่ฎจ่ฎบ่ฏ้ข
