Improvements
- Allowlist adds "detecting and recording attack requests when whitelisting" . Attack log of allowlist add the name of the Rule
- Allow Enable/Disable enhanced rules. Pro version allow advaned security rules, or further configuration of rules
- Improve Challenge
- Pro version allow customizing the page of challenge
- Pro version allow choosing sliding verificaiton, allow modifying the validity period of the verification
- Pro version allow HA synchronizatio by setting master node and slave node in System Settings -> Configuration Synchronization
- Optimize error log when tengine is abnormal
Fix
- Update IP geolocation library and fix some IP geolocation display errors
- Fix the problem that static sites cannot access subdirectory paths normally
- Fix the problem that the attack log is not correctly recorded as whitelist release when low-risk events hit the whitelist
- Fix the problem that X-Forwarded-Host is set to $http_host by default when passing it to the upstream server
- Fix the problem of incorrect resource settings for site resource collection exclusion
- Fix the problem that the site configuration is lost abnormally after ssl_ciphers is saved
- Remove bridge container (merge into mgt)
这是一个从 https://github.com/chaitin/SafeLine/releases/tag/v7.0.1 下的原始话题分离的讨论话题
