Added
- In Protection Log->Attack Detection->Attack Log, "View IP Profile" has been added, which allows you to directly jump to Changting IP Intelligence and comprehensively analyze the attack behavior of the IP
- Sites that support adding "redirection"
- Sites built with static files support setting default pages and behaviors when pages do not exist. Can be used to adapt History routing mode (#1049)
- System Settings -> Data Cleanup supports separate configuration of protection log and statistics cleanup
- Site global configuration, site advanced configuration, support enabling HTTP/1.0 (new installation is not enabled by default):
- Site global configuration, site advanced configuration, support resetting XFF
- Professional version supports customizing global and site Header operations and SSL cipher:
- Professional version supports customizing authentication pages
Fixed
- Fix the problem that HSTS configuration does not take effect when requesting 404
- Fix the problem that the site details->website routing page occasionally times out
这是一个从 https://github.com/chaitin/SafeLine/releases/tag/v6.9.0 下的原始话题分离的讨论话题
