SafeLine-CE 6.8.0
Improvements
  • Change the code of Challenge to 468 to avoid being cached by CDN
  • Reduce the probability of deadlock in luigi
Fix
  • Mistakenly return 504 error when 502 Bad Gateway
  • Access log and error log in site detail do not refresh automatically
  • Advanced statistics sometimes have data of 0
  • Sites Serving as Static Files mistakenly record some rate-limiting logs caused by 127.0.0.1
这是一个从 https://github.com/chaitin/SafeLine/releases/tag/v6.8.0 下的原始话题分离的讨论话题
