SafeLine-CE 6.3.0
Added
  • Dynamic protection adds image watermarks, which can add domain name watermarks to images. In the professional version, you can customize the watermark text or image
  • Supports configuring frequency limits for each site
  • The high-frequency access restrictions of the professional version support setting the excluded Content-Type when counting
  • The frequency limit log is now moved to the "Protection Log" menu.
    Optimize some UI interaction details
Fixed
  • Fixed the problem that Data Statistics -> Basic Statistics -> 30-day interception data is not updated
  • Fixed the problem that too much data is calculated in Data Statistics -> Today's interception of independent IP
  • Fixed the problem that the interception and attack blocking counts of Data Statistics include the release request
这是一个从 https://github.com/chaitin/SafeLine/releases/tag/v6.3.0 下的原始话题分离的讨论话题
