SafeLine-CE 6.2.1
Improvements:
  • Pro version allows adding multiple users in Sites Auth:
  • Allow modifying the default user name (#957)
  • Add site name to pop-up window when deleting a site (#943)
  • Dynamic
    • HTML encryption determines whether to encrypt based on response Body instead of Content-Type
    • Quick encryption in pro version does not show the SafeLine logo
  • "Limit High-frequency Attack" also count Blacklist interception (#817)
  • "Search Engine Spider IP" updates automatically every day
  • Upstream health check does not alarm when get http code 401 or 405 (#973)
Fixes:
  • Revoke of the Rate limited IP is invalid sometimes
  • Challenge may be cached by CDN and cause an infinite loop
  • The site title and icon may be updated inaccurately during daily update
这是一个从 https://github.com/chaitin/SafeLine/releases/tag/v6.2.1 下的原始话题分离的讨论话题
