大家好,我是磊磊落落,目前我在技术上主要关注:Java、Golang、架构设计、云原生和自动化测试。欢迎来我的博客(leileiluoluo.com)获取我的最近更新!
本文由 Java 中常见的面试题「为什么重写 equals
方法时必须同时重写 hashCode
方法?」所引出。渐进式探讨关于 hashCode
的三个问题:hashCode
方法的作用以及 hashCode
方法与 equals
方法的关系?为什么重写 equals
方法时必须同时重写 hashCode
方法?以及如何重写 hashCode
方法?
我们知道,Java 中 Object
类是所有类的父类,而 hashCode
是 Object
类中定义的方法,所以每个类都会默认拥有一个 hashCode
方法。
如下为 hashCode
方法在 Object
类中的定义:
package java.lang;
public class Object {
/** * Returns a hash code value for the object. This method is * supported for the benefit of hash tables such as those provided by * `java.util.HashMap`. * * The general contract of `hashCode` is: * * a) Whenever it is invoked on the same object more than once during * an execution of a Java application, the `hashCode` method must * consistently return the same integer, provided no information * used in `equals` comparisons on the object is modified. * This integer need not remain consistent from one execution of an * application to another execution of the same application. * * b) If two objects are equal according to the `equals(Object)` method, * then calling the `hashCode` method on each of the two objects must * produce the same integer result. * * c) It is not required that if two objects are unequal according to the * `equals(Object)` method, then calling the `hashCode` method on each of * the two objects must produce distinct integer results. * However, the programmer should be aware that producing distinct integer * results for unequal objects may improve the performance of hash tables. */ @IntrinsicCandidate public native int hashCode(); /** * Indicates whether some other object is "equal to" this one. * * @apiNote * It is generally necessary to override the `hashCode` method whenever this * method is overridden, so as to maintain the general contract for the `hashCode` * method, which states that equal objects must have equal hash codes. */ public boolean equals(Object obj) { return (this == obj); }
可以看到,hashCode
方法用于生成一个整数,其是一个原生方法且使用 @IntrinsicCandidate
注解修饰,表示其实现完全依赖于 JVM,不同的 JVM 可能有不同的实现,常见的实现有使用伪随机数等。
为什么 Object
类中要定义一个 hashCode
方法呢?此外我们还注意到,equals
方法同样被定义在 Object
类中,这两个方法之间有什么关系呢?
1 hashCode 方法的作用以及 hashCode 方法与 equals 方法的关系
Java 中,hashCode
方法主要是为了配合哈希表来使用的。
哈希表是存储键值(Key Value)对数据的一种数据结构。其通过将键映射到表中一个位置来访问数据,以加快查找速度,这个映射函数即被称为哈希函数(Hash Function)。Java 中的 HashSet
、Hashtable
与 HashMap
均使用了哈希表。
假定我们想实现一个 Set
,其存放的数据是不允许重复的,如果不借助哈希表,应该怎么来实现呢?
我们能想到的一个办法是:当一个对象要被存入 Set
时,调用其 equals
方法与 Set
中的已有对象逐个进行比较,只有其与所有已有对象都不 Equal 时才可将其存入 Set
。而一般来说,equals
方法的实现都比较重,需要将对象中的各个关键字段逐个进行比较,这在存放的对象特别多的时候效率会非常低下。
而如果借助哈希表来实现呢?我们知道 Java 中 HashSet
是借用 HashMap
来实现的,HashMap
是怎么在添加记录的时候提升效率的呢?
HashMap
存储结构为哈希表,在添加一个键值对时,有如下步骤:
- a) 调用键对象的
hashCode
方法获取其哈希值; - b) 与现有哈希值逐个进行比较,若不相等,则直接存入哈希表;
- c) 若有相等的,再调用键对象的
equals
方法进行比较,若不 Equal,则存入哈希表(此两个对象哈希冲突,需要增加一个链表来存放对象的引用);若 Equal,则不存入。
可以看到,借助哈希表实现去重集合的话,因首先会判断哈希值是否相等,只有不相等时才会调用 equals
方法,所以只要哈希算法足够好,就会省去很多 equals
方法的调用。
此外,哈希算法选用得当的话(理想的哈希算法是针对不同的对象,生成的哈希值可以均匀分布在整个 int
区间上,现实中是越接近越好),哈希表的检索效率会非常高,没有一次哈希冲突的话,检索记录的时间复杂度为 O(1)
;最坏情况,hashCode
全部相等,存储结构完全变成了一个链表,那么检索记录的时间复杂度会变为 O(N)
总结该部分,我们可以看到:hashCode
一般与 equals
一起使用,两个对象作「相等」比较时,因判断 hashCode
是判断 equals
的先决条件,所以两者使用必须遵循一定的约束。hashCode
方法的注释上即说明了其与 equals
方法一起使用时需要遵循的三个通用约定:
- 同一对象多次调用
hashCode
方法,必须返回相同的整数值; - 对于两个对象
a
和b
,若a.equals(b)
,则a.hashCode()
与b.hashCode()
必须相同; - 对于两个对象
a
和b
,若!a.equals(b)
,则a.hashCode()
并不一定得与b.hashCode()
不相同。
知道了 hashCode
方法的作用以及 hashCode
方法与 equals
方法的关系后,下面探讨一下为什么重写 equals
方法时必须同时重写 hashCode
方法。
2 为什么重写 equals 方法时必须同时重写 hashCode 方法?
上面介绍了 hashCode
方法注释上列出的三个通用约定,equals
方法的注释上也有这么一句话:「每当重写 equals
方法时,都需要重写 hashCode
方法,这样才没有破坏 hashCode
方法的通用约定,即:两个对象为 Equal 的话(调用 equals
方法为 true
), 那么这两个对象分别调用 hashCode
方法也需要返回相同的哈希值」。
所以只重写 equals
方法不重写 hashCode
方法的话,可能会造成两个对象调用 equals
方法为 true
,而 hashCode
值不同的情形,这样即可能造成异常的行为。
最后探讨一下如何重写 hashCode
方法。
3 如何重写 hashCode 方法?
下面定义了一个 User
类:
// src/test/java/com/example/demo/model/User.java package com.example.demo.model;
public class User {
private final String name;
private final Integer age;
private final Gender gender;public User(String name, Integer age, Gender gender) { this.name = name; this.age = age; this.gender = gender; } public enum Gender { MALE, FEMALE }
该类有三个属性:name
、age
和 gender
若不重写 User
类的 hashCode
与 equals
方法的话,则会使用 Object
类定义的默认实现,即:hashCode
是 JVM 生成的一个伪随机数,equals
比较的是两个引用的地址。
下面测试代码新建了两个逻辑上「相等」的 User
对象:user1
与 user2
,然后比较 user1.equals(user2)
与 user1.hashCode() == user2.hashCode()
,发现结果均为 false
;然后将此两个对象作为键放入 HashMap
后,查看 HashMap
的 size
,结果 为 2
,表示两个对象均被添加了进去。这即是不重写 hashCode
与 equals
方法发生的「异常行为」。
// 不重写 User 类的 hashCode 与 equals 方法 User user1 = new User("Larry", 18, User.Gender.MALE); User user2 = new User("Larry", 18, User.Gender.MALE);
System.out.println(user1.equals(user2)); // false
System.out.println(user1.hashCode() == user2.hashCode()); // false
Map<user, boolean=“”> map = new HashMap<>();
map.put(user1, true);
map.put(user2, true);
System.out.println(map.size()); // 2
</user,>
下面尝试在 User
类中重写一下 hashCode
与 equals
方法:
import java.util.Objects;
public class User {
// …@Override public int hashCode() { int result = name.hashCode(); result = 31 * result + Integer.hashCode(age); result = 31 * result + gender.toString().hashCode(); return result; // Another way: using Object.hash() // return Objects.hash(name, age, gender); } @Override public boolean equals(Object obj) { if (null == obj) { return false; } if (obj == this) { return true; } if (!(obj instanceof User user)) { return false; } return Objects.equals(user.name, name) && Objects.equals(user.age, age) && Objects.equals(user.gender, gender); }
重写 hashCode
方法使用的算法如下:
$\boldsymbol {hash} = {val[0] \times 31^{(n-1)} + val[1] \times 31^{(n-2)} + ... + val[n-1]}$
该算法公式借用了 JDK 中「String.hashCode()」的实现逻辑,即:按属性依次计算哈希结果,当前属性的哈希结果为上一个属性的哈希结果乘以 31
并加上当前属性的哈希值(currentVal = 31 * previousVal + hash(currentPropertity)
),直至所有属性计算完毕,最终的结果即为对象的哈希值。至于为什么要乘以 31
呢?原因是在于:其是一个奇素数,可以更好的保留信息,若是偶数的话,乘一个偶数相当于移位,超出的话会丢失信息;此外乘以 31
会被现代虚拟机优化为移位和减法来实现(31 * i == (i << 5) - i
),非常的高效。此外还可以直接调用 Objects.hash(prop1, prop2, prop3, ...)
来获取一个哈希值。
重写 equals
方法的逻辑非常简单,即:判断是否为 User
对象且所有字段是否一致。
再次使用如下代码测试一下,发现 user1.equals(user2)
结果均为 true
;调用 HashMap
的 put
方法将 user1
与 user2
均 put
后,size
为 1
。这样即符合了我们的期望。
// 重写 User 类的 hashCode 与 equals 方法 User user1 = new User("Larry", 18, User.Gender.MALE); User user2 = new User("Larry", 18, User.Gender.MALE);
System.out.println(user1.equals(user2)); // true
System.out.println(user1.hashCode() == user2.hashCode()); // true
System.out.println(map.size()); // 1
</user,>
综上,本文解释了为什么重写 equals
方法时必须同时重写 hashCode
方法的缘由,并且给出了示例代码。完整示例代码已提交至本人 GitHub,欢迎关注或 Fork。
参考资料
这是一个从 https://juejin.cn/post/7369044948330479668 下的原始话题分离的讨论话题
