Commodore 64 runs AI to generate images
A developer has built a Generative AI tool for the Commodore 64, allowing it to create 8x8 sprites at 64x64 resolution. The project uses a probabilistic PCA algorithm trained on a modern computer and runs on the Commodore 64, demonstrating that even old hardware can be used for AI tasks with patience and determination. [summary] [comments]
这是一个从 https://www.tomshardware.com/tech-industry/artificial-intelligence/commodore-64-can-use-ai-to-generate-8x8-sprites-takes-20-minutes-for-90-iterations 下的原始话题分离的讨论话题
