Add sysctl to disable Nagle's algorithm (RFC 896 – Congestion Control)
Job Snijders proposes adding a sysctl to disable Nagle’s algorithm, which can cause latency issues with small packets, and suggests setting it to 1 by default. The change introduces a new sysctl net.inet.tcp.nodelay that sets TCP_NODELAY on all TCP sockets if set to 1. [summary] [comments]
这是一个从 https://marc.info/?l=openbsd-tech&m=171562561424289 下的原始话题分离的讨论话题
